VAG Software
  • Thread starter4493ph
4493ph
I am trying to code a new key on my VW T5. I already have VCDS but I need software to read the immobilizer code (SKC code). I think I need VAG EEPROM Programmer v1.19g. But any advice would be appreciated.
Reactions:Mblbesi
  • A
    Given by AZCKNCLLC
The best investment for VAG Immo is VVDI2. If it is a one-off thing, make friends with your local mechanic and maybe he will help you extract the SKC code.
What ECU does your T5 have?
I think VAG EEPROM Programmer can't read Immo T5 PIN. The cheapest solution is to read ECU EEPROM or cluster, but it requires special tools and knowledge.
I also agree that VVDI2 is the best investment for VAG. Depending on your location you may have other options for SKC.
  • User
Daniulis
  • no2spam
theRogue
theRogue
makswells1
