VCDS Equivalent for Ford
  • Thread starterdoctor_bigfoot
doctor_bigfoot
I know VCDS for VW and Audi, but is there something similar for Ford cars?
Reactions:maba41 and berkesmob
  • S
    Given by sraj
Yes, FORScan is a software for Ford and Mazda that you can download and try for free here.
Works with cheap ELM327 or Passthru or these.
Supported adapters :
  • OBDLink EX USB, recommended USB adapter for Windows version of FORScan, also for configuration and programming functions
  • OBDLink MX+ BT, recommended Bluetooth adapter for Lite versions of FORScan (iOS, Android)
  • vLinker FS USB, recommended USB adapter for Windows version of FORScan, also for configuration and programming functions
  • vLinker FD BT, recommended Bluetooth adapter for FORScan Lite for Android
  • OBDLink SX/LX/MX
  • ELS27 (STN1170/2120)
  • ELM327-compatible (fully compatible with original ELM327...
FORScan is available and cheap, there is also a free version.
Reactions:powolutku88, berkesmob and muller
Yes, FORScan is very good for Ford cars.
Reactions:biturbo
Ford IDS, if there is something to connect to.
UCDS is similar to VCDS.
FORScan. But make sure you have a MS-CAN compatible cable.
FORScan is a software developed specifically for Ford and Mazda. It requires a certain level of knowledge. Do it at your own risk. You can update the software, as well as use special functions such as DPF regeneration, ABS bleeding, etc.
Reactions:Naheem
  • OBDLink SX/LX/MX
  • ELM327-compatible (fully compatible with original ELM327, please also see important note below)
  • J2534 Passthru
Reactions:maba41
FORScan is the best and cheapest option, also works great with Scanmatik 2 PRO (original or clone), which is the best tool, works great with many other programs.
I think the best option would be to use the IDS 110 with VCM or Mongoose J2534 which is good for diesel power balancing and programming new factory updates.
  • User
Daniulis
yosef15
  • yosef15
HXKeys
HXKeys
  • 4493ph
hyacinth
