VCX SE Setup Files for - Vediamo v04.02.02 and v05.01.01
  •  Extras Download
  • Thread startero_Rage_o
o_Rage_o
o_Rage_o
Here is a working set of files for both Vediamo 4.02.02 and 5.01.01 for use with VCX SE.
0) Ensure that VX Manager is installed, and under drivers tab, both Passthru, and C6 are fully installed.
1) Run Notepad in Administrator mode.
2) Open "C:\program files (x86)\Vediamo\Ceaser\Driver\slave.ini".
3) Replace all text with the text from the appropriate attached file depending on your version of Vediamo.
Enjoy!
  • VCX SE Slave.ini for Vediamo 5.01.01.rar
  • VCX SE Slave.ini for Vediamo 4.02.02.rar
Reactions:Mingo, emirkaan, smokiness and 43 others
I installed Vediamo 5.01.01 and followed your instructions exactly, and yes I downloaded the right one from here. I have this hardware VXDIAG VCX SE DOIP Full Brands 11. Unfortunately Vediamo with VXDIAG can't connect to for example IC176 or MD40 on my A-Class, 2015 W176. What am I doing wrong?
It is not very wise to work with virtual interfaces of the entire Allscanner family, including your VCX SE and any virtual interfaces in general, both on Vediamo and Xentry. Some parts work, others don't. The real interfaces for Vediamo were originally eCOM, which has the most programming capabilities (the original eCOM, not the 20xx version), and C4, but with a lower level of programming access. Read this forum of my friends, you will find many answers here.
For this car I assume you will be using Vediamo 4 and CBF files. Do you have SMR-D, for which Vediamo 5 is more specialized? Also make sure that in VX Manager you have installed the C6 adapter under the automotive section.
Reactions:bohrg1
Benz C6 and Passthru installed in VX Manager.
o_Rage_o
o_Rage_o
o_Rage_o
