W164 Rear Tailgate
  • Thread starterabrish27
abrish27
W164 rear tailgate does not close. I checked all the wiring associated with the rear tailgate, the wires are fine. No fault code found.
Check the engine's functionality (under the spare wheel), water often accumulates there and floods it. The rear one may also be damaged.
Reactions:abrish27
Problem solved. The problem was that the rear trunk lid control unit was faulty due to water getting into the control unit. Thanks for your help.
I had a problem with the pinch sensor. Sometimes it just gets water in it and it stops working. It's the black molding by the tail lights that goes all the way up to the roof. At least try that. Do you have a tool that can give you more information?
EdoM
  • EdoM
EdoM
EdoM
  • User
User
karakan08
  • karakan08
karakan08
karakan08
