dizel088
- 71
I have coded headlights on W167 many times and everything was always fine, and I have heard many times that there is some kind of catch, but I have never encountered it. The background is as follows. I replaced the headlight unit with an old W167, everything worked, there were no errors. I know that when replacing a headlight, you need to enter the LED code and decided to do everything correctly. I did so and immediately an error appeared on KI, there are errors there too, if you follow them, it says that SCN is needed. Using DTS Monaco, I transfer the coding from one headlight to another, nothing changes in the PXL block, the errors remain relevant. Can someone tell me what to do?
