W213 Activate Automatic High Beam
  • Thread starterKarahan
Try the new one first. If it doesn't work, switch to another one.
But I think you have a different problem. NRC13 is "Incorrect message length or invalid format", so I think you have selected a completely different file.
This error is a bad project file. I got the same error a few days ago when I was doing a high beam assist with the same headlight as you.
After I used the new project file, I was able to write coding.
This error I think means that the coding of the project files is not compatible with the firmware in the ECU. Just use a newer file.
I used the DTS Monaco database from here. I use the PKW_SMRD_XXX projects because these projects contain all the ECU files for a specific car.
However, I got the same error as you. I checked the project files and they were much older than the files in the BR_213 project.
So I just copied all the BR_XXX project files to the PWK_SMRD_XXX project and thus updated all the project files. Then I connected to the car and used this updated project and everything worked like a charm. XXX = your car number.
Also, I read that if you turn on automatic high beams and you still have to turn the high beams to the "ON" position every time you start the car, then it means the firmware needs to be updated.
My car has the latest firmware version installed. So, by turning on the high beam assist function, I automatically see a big "A" when it gets dark.
Reactions:Karahan
A good upgrade to the car with the same equipment. I'll try to use BR_213, if it doesn't work, I'll use PKW.
How did you update the firmware to the latest version? Can you explain this?
I didn't have to update the firmware at all. The latest version was already installed when I bought it.
I haven't reflashed anything yet, but there are instructions and I need to look for them.
Reactions:Karahan
Kino
  • Kino
Kino
Kino
  • jadjady20
BMGarage
  • omer7166
lmdtm
