W220 SRS Replacement
  • Thread starterbarehill
barehill
My W220 2004 has a red SRS "Visit Workshop" light on. DAS returns several errors, including an SRS module fault error. I used DAS to reset it but to no avail. Can I buy a used module?
Yes. Buy used SRS ECU and change coding if needed. All special functions are available in regular DAS version.
You can also reset internal ECU faults. I don't remember the exact steps, but you will have to unlock the ECU and run some additional commands in development mode -> activations.
I hope this helps you.
Tried this method for W163 SRS - without results :)
What is the part number of the SRS module? Maybe I can help you fix the internal error.
  • komote
  • BMGarage
Organicrobot
  • Organicrobot
Organicrobot
Organicrobot
