W447 V-Class AdBlue Countdown Reset
  • Thread starterasigur
asigur
I had a problem with the NOX sensor in my van and did the repair, replaced the sensor and initialized it with Xentry. No other error codes in the ECU or SCR, all clear except the countdown message in the ECU.
I have a 2018 V-Class (W447) and I can't reset the AdBlue warning message.
I don't seem to have the correct CBF file!? I have one CR41.CBF, I can connect to it, but it seems to be wrong.
When I tried to unlock the ECU, I got the correct response (67 0C) with "CR41_cr41r_secB_12_37_01.dll".
Anyway, when I connect to the ECU with my CBF file (Vediamo 5, Openport 2.0), there is DJ "En...9A" but no "DJ Ent... BC".
WarmsZenario's reset also failed.
So I'm asking you to help me get rid of the countdown message, please!
Maybe I just need the correct CBF file to work with my van's ECU.
My Xentry installation does not contain CR41 or CR41R files, but does contain CR42, CR43, etc.
Just in case, I am attaching a file for identifying the Xentry ECU.
Reactions:dexxa05 and prt93
I think it's because of bad files, but try using the SMR-D file with DTS Monaco. It should be in the Xentry folder, but if not, I can provide you with the file.
Reactions:audiomeca
Yes, I have SMR-D files and DTS 9, but I am not familiar with DTS Monaco.
Thank you for trying to help me! I really appreciate it.
But this file is wrong, I tried.
ECU - CR41. I did it now. Found the necessary CBF file and voila - the display is clean.
In DTS Monaco:
Open temp. workspace CR41 (4 cylinder, EDC17C66).
Algemeine jobs:
DJ Entriegelung 9A - double click on it.
DJ Entriegelung BC - double click on it.
Search criteria:
Reset SCR Warnszenario - double click on it.
Search criteria:
Soft Reset - double click on it.
Done.
Reactions:Salidol, kerekt, mercfreak and 2 others
There is no such thing as a "temporary workspace" in DTS 9. But thanks anyway!
My problem is already solved. I will definitely study DTS 9 later.
I'm using DTS Monaco 8.16. I just wanted to share the instructions in case anyone else has the same problem.
Reactions:Salidol and asigur
jatoi92
  • jatoi92
cmkfarooque
