XENTRY v06.2023 Simple Activation
  •  Activation Download
Moderator
Staff member
Developer
XENTRY.v06.2023.Simple.Activation_autogmt.com.01
XENTRY.v06.2023.Simple.Activation_autogmt.com.02 XENTRY.v06.2023.Simple.Activation_autogmt.com.03 XENTRY.v06.2023.Simple.Activation_autogmt.com.04
This is not a repack of FREE solutions.
The activator also has no relation to my commercial activation.
What is this?
  • XENTRY activation for version 06.2023
  • It does not use that crazy "XentryAPI" dll loader (There is NO DEPENDENCY on "SECURE BOOT" and no memory garbage)
  • Naturally, no problems with FREEZING or CLOSING
  • The XENTRY key is already implanted (Taken from a FREE generator, so the functionality is very poor)
    Described here: https://autogmt.com/threads/xentry-developer-mode.52/#post-102
  • Can be used on virtual machines or anywhere else without any stupid "solutions" (XENTRY always has Hardware ID: 111111111111 and App ID: 252)
  • The default offline login account with userID: XENTRY (userID: USER for future versions) was implanted (With the same limited functionality as it was published)
    Login parameters have been changed for your convenience (User name: 1, Password: 1)
  • Blacklists disabled
How to install?
The "XentryAPI" dll loader must be disabled/removed/killed if it was installed.
You will need to have a clean installation of XDOS or XPT v06.2023 release, not BETA, into DEFAULT directory, without any stupid patches, loaders and etc.
XDOS/XPT can be updated with AddOns before or after as you wish.
Run the activator, reboot the system and use XENTRY/DAS.
You do not need to enter a key in ConfigAssist, NOTHING IS NEEDED.
The folders (C:\ProgramData\LicDir) and (C:\Program Files (x86)\Mercedes-Benz\Xentry\llist) are empty after activation.
If updated files will appear in the "llist" directory after AddOns, ignore them, this directory is not used by XPT/XDOS.
You can also add whatever you want to the activated system.
XENTRY Diagnostics OpenShell or XENTRY Pass Thru version: v06.2023
OS: MS Windows 10 and above
Installed size: 7.70 MB
  • XENTRY.v06.2023.Simple.Activation_autogmt.com.rar
  • XENTRY.v06.2023.Simple.Activation.Uninstaller_autogmt.com.rar
  • Love
Reactions:est4tic, odaishisama, oktyszgn and 121 others
How do I uninstall this?
Reactions:MarcusBHP, Shirazkaram, Gayar and 1 other person
I will write an uninstaller this night.
Reactions:oktyszgn, dursunum, MarcusBHP and 3 others
"XENTRY.v06.2023.Simple.Activation.Uninstaller_autogmt.com.rar" has been added to attachments.
Reactions:oktyszgn, saffirmo, MarcusBHP and 5 others
Could you allow us to specify the install location? I have XPT installed on an external SSD due to space limitations so the cr@ck cannot be applied to the default locations.
Reactions:oktyszgn, MarcusBHP and Shirazkaram
Default path only: "C:\Program Files (x86)\Mercedes-Benz".
Reactions:oktyszgn, saffirmo, MarcusBHP and 1 other person
I understand that, but unfortunately my laptop's HDD is not big enough to install Xentry. Because of this I installed it on an external SSD. Is it possible to create a configuration file for us in which we specify the installation locations? Thank you for taking the time to answer me.
I'm not going to rewrite everything. Made for the DEFAULT directory only.
Reactions:Bigovic, jstricko, Peter5 and 1 other person
Using an external HDD/SDD is some ancient sh.t, just upgrade the internal hard disk to a larger SSD and clone the old one onto it.
Reactions:DesertBenz602 and Bigovic
XENTRY v06.2023 Simple Activation, I have already downloaded this version and tried it out, it works perfectly, but with another version of XENTRY 09.2023 it does not work.
Reactions:GFC
  • XENTRY Diagnostics
