360 Camera
  • Thread startermyelkovan
myelkovan
Any tip for Mercedes E350 front camera problem? Xentry caanot start adaptation and says electrical problem. Should I replace the camera? How can I test the camera any idea?
Reactions:wang
Hello,
Does the camera give any faultcodes?
I dont remember the code. yesterday I installed xentry 2022 and it gives me following error and I cannot solve the problem and cannot check the fault code anymore
I noticed that the front grill and maybe the cam was replaced before.
I would like to add that you maybe need software update, or do you already have the latest software installed?
Dear Stutgart-Benz
Are you in Stutgart - Germany? I was there for a month. In the picture you see the error code of camera. But I am not sure if it is the correct camera or not because the previous owner of the car replaced the grill. The car is 2014 mercedes e350 coupe. w207. before buying a new camera I plan to test it in the rear, so I will see if it is the same part number or not. I am not sure if front and the rear are the same part.
I need update the software not only camera but headlight. Howevert my xcenty cannot do it. I mean the version that we download here.
How can we make software update? Is it possible?
hello! did you manage to update?
No. I need to buy a new camera. Update procedure is failing with electrical error
Did you manage to solve this issue as I have a similar issue?
A new/used working camera will solve this problem.
  • User
User
  • IlanISR
IlanISR
  • plamen
dobinh211
