Moderator
Staff member
Developer
- Solutions
- 15
- 2,299
KIT3/KIT4 backgrounds (archive attached):
Daimler Truck Diagnostics Platform Independent and Pass-Through v12.2023
Firstly, I don’t have normal words to describe this brilliant creation of very "smart and competent" programmers, it’s simply the crown of creativity and thought in IT world.
This applies to all versions of XENTRY 12.2023 releases.
Just look at the quality of the backgrounds that I took from the original KITs.
To be able to install the Daimler Truck Diagnostics, you must first uninstall the XENTRY Diagnosis Pass Thru or OpenShell version.
Check if you also have the programs "Update Center" and/or "XENTRY PDF Printer" installed. All of them need to be uninstalled.
It is not possible to have both versions installed on the operating system, as they both access the same save-files and registry entries.
The same applies to Kit 3 and Kit 4, once the devices have been migrated to DT software, they cannot be reset to Mercedes-Benz AG software.
They also wrote that the existing startkeys provided by MBAG will expire on January 10th, 2024. As of this day DT is taking over custody of the software and startkeys on the devices.
Everything is based on XENTRY OpenShell.
Now we have Daimler Truck Platform Independent Diagnostics DTPID like XDOS and Daimler Truck Diagnostics Pass-Through DTDPT like XPT.
The free ugly activation published everywhere was not tested, but my commercial activation was remade specifically for the DT version and some functions were added to the activation key, so my keygen was also rebuilt.
SDconnect C4 was cut from this version.
The XENTRY Update Service has been removed, so the database is on the hard drive.
These are the final releases.
OS: MS Windows 10 and above
Installed size: 27.20 GB
Daimler.Truck.Platform.Independent.Diagnostics.v12.2023.zipExternal link · Views: 32
Daimler.Truck.Diagnostics.Pass-Through.v12.2023.zipExternal link · Views: 22
