Disabling HU6 Firewall on A220 W177 with DTS Monaco v8.16
  • Thread starterrocks
rocks
I only see level 1 and level 60. Will it be bad if I disable both if I'm not sure which one to disable?
Reactions:Dervo90
Disable both. You will see if the coding works or not. Or try the first option, and if it does not work, try both.
Reactions:Stanislav and Dervo90
I guess I'll have to use both since the first one didn't seem to change anything. I haven't checked to see if the actual coding is still there, but the AMG I'm trying to activate didn't show up on startup. I do this when I have the chance.
What are you trying to enable with coding? AMG menu or AMG welcome logo in MBUX?
I enabled AMG menu and Supersport, but nothing changed, although the coding was saved.
Can you post the IC coding after connecting? It should be higher/greater or at least 033.
I used level 1. I activated the AMG menu on MBUX, but I think for the IC I need to flash it with the AMG IC first. I was able to activate some other things too. So I think the firewall has nothing to do with the AMG menu not showing up on the IC because its coding is preserved.
  • smokiness
smokiness
  • lonewolf2k4
Skelebob9
rimedre
supra1khp5
