ME9.7 how to make a used ECU virgin
  • Thread starterisookgoed
isookgoed
Because the ECU in W211 ME9.7 often breaks due to overheating, because they are mounted on the intake manifold, I am looking for a way to make a used ECU virgin without soldering so that I can use the DAS drive authorization to install the fin in the ECU. can write
Vvdi should do it
Which version of VVDI do you need to be able to write the VIN into the ECU?
Check with autel im 508, 608 pro or pro 2 tools
Reactions:biturbo
DAS can write VIN and enter factory mode
DAS Drive Authorization System is sometimes difficult to write the vin into the ecu, if the part numbers are not the same, that is my experience, then I do it with diagzon online scn, which works.
Reactions:marcos3222
Thanks for your input, I think I'll go for the CGDI, it seems they have reasonable support.
We have very good experience with Xhorse VVDI BGA. Most FBS3 problems be solved. Pricing is really fair. Using it for over 4 Year without any issues.
Hi! If not solved it, send a file to the private conversation with VIN & part number to get new file + SCN Update.
CGDI will be able to reset the block, but will not change the VIN number.
The VIN number can be easily changed using Vediamo or DAS with the engineering menu.
Reactions:AlexTS and police21063
jatoi92
  • jatoi92
cmkfarooque
RicoChef
RicoChef
  • andresz28
mbspecialist79
