Mercedes-Benz R107 ABS problem
  • Thread starterryanludik
ryanludik
I have a Mercedes-Benz R107 500SL that has an ABS light that comes on after starting. It has basic ABS.
I have the necessary Mercedes-Benz ABS and ASR test equipment to perform diagnostics, however I have lost the documentation for the test procedure.
I don't have access to WIS where I know this document can be found. Does anyone have a PDF of the ABS and ASR inspection procedure that I can obtain?
It's a waste of time when things like the OVP, control module and pump relay can be bad, as I had before on my own W126 500SE, and the testing procedure is the only way to do the check correctly without guessing.
Maybe this will help you.
  • 560SL ABS diagnosis.pdf
Reactions:excash
  • dgioc
dgioc
