Mercedes-Benz WIS ASRA Standalone v07.2021
  •  Activation Download
Moderator
Staff member
Developer
Mercedes-Benz.WIS.ASRA.Standalone.v07.2021_autogmt.com.01
Mercedes-Benz.WIS.ASRA.Standalone.v07.2021_autogmt.com.05
Mercedes-Benz.WIS.ASRA.Standalone.v07.2021_autogmt.com.02 Mercedes-Benz.WIS.ASRA.Standalone.v07.2021_autogmt.com.03 Mercedes-Benz.WIS.ASRA.Standalone.v07.2021_autogmt.com.04
The famous electronic guide with repair and maintenance information for Mercedes-Benz vehicles.
This is the last offline version, future versions will be online only.
If you see a newer one than 10.2021, then it is pure FAKE.
Before installing the activated Mercedes-Benz WIS ASRA Standalone package, you must install XENTRY in the DEFAULT directory (C:\Program Files (x86)\Mercedes-Benz).
WIS will be installed to the XDOS or XPT this folder.
Logs and an impressive number of unnecessary directories and files were removed.
The program is fully functional and already activated with a time-unlimited right license from my keygen for cars, 4xWDs, light transporters, heavy transporters, trucks, buses, Unimogs and Smarts.
And of course you can run WIS from DAS and XENTRY, it is fully linked.
You do not need to use any other tools or anything else at all, just run and use.
If you are using XENTRY with FREE activation with public keygen, you also need to apply the second file from the attachments.
This "Update" is not needed for my XENTRY activation.
The topic is no longer relevant, the new version is here:
XENTRY Diagnostics OpenShell or XENTRY Pass Thru version: v09.2021 and above
OS: MS Windows 7 and above
Installed size: 16.72 GB
  • Mercedes-Benz.WIS.ASRA.Standalone.v07.2021_autogmt.com.rar
  • Mercedes-Benz.WIS.ASRA.Standalone.v07.2021.Update_autogmt.com.rar
  • Love
Reactions:Vaxilmore, edith, rintaro and 148 others
WIS Standalone works great (y)
Reactions:rintaro, Milaaafps, jstricko and 6 others
Hey R00TR0w (y)
Installed this alongside a Xentry Passthru 23.6.3 installation, WIS Standalone works great (y)
I don't seem to be getting the option for WIS/ASRA in Xentry Passthru 23.6.3 though. Am I doing something wrong? :LOL:
Xentry is installed in the default installation path.
Reactions:immike and zakarea
I do not understand anything from above.
First. If you ask something, then give the exact information through the private conversation system.
I am not a god to debug your brains.
WIS/ASRA works without any problems with normal activation.
PS. You may not be able to run WIS from DAS (possible from XENTRY too) if you use that crappy published keygen and etc.
Of course I did not check with that.
In order to sync XDOS with these crappy keys, you need to rebuild the entire system in order for it to work correctly.
A few years ago I did the same for WIS, but I need more information like I said earlier.
Reactions:Milaaafps, Nico71, davidnguyen1981 and 5 others
I have added "Mercedes-Benz.WIS.ASRA.Standalone.v07.2021.Update_autogmt.com.rar" to attachments.
Might be useful if you are using XENTRY with a FREE keygen posted everywhere.
The description was also updated.
Reactions:hjp, Kroticker, jjajjb2 and 5 others
Anyone who already has WIS Standalone installed and has noticed that they cannot access WIS service media online: go to the WIS folder (either where the software is located or where you installed it) and then in the config folder you will find "secure_linkout_cfg.xml".
Open it, find the line with the WIS service media URL and change it from (*.daimler.com) to (*.i.mercedes-benz.com).
Then do the same in the "wis_cfg.xml" file.
I believe the same settings can be updated in EWA based versions of WIS to get WSM working again.
Reactions:Milaaafps, Antim, hjp and 4 others
WIS/ASRA offline mode was completely disabled in XENTRY v09.2023, but I have enabled it again.
The software was recompiled to support current and future versions.
Link updated
Reactions:jannevemvet, powolutku88, sirius and 11 others
Tell me, are there illustrations of X164 and W164 in this assembly? Or is it not worth installing such a new build?
Reactions:Milaaafps and ExtentedXXX
It is not necessary to install. For old cars, version 18 should be more than enough.
Reactions:easton2222 and sonerafedora
Thank you, indeed, in the new program a lot is cut out from the old cars.
Reactions:easton2222, sonerafedora and ExtentedXXX
9K
