Mercedes COMAND NTG4x, NTG5x, NTG6, NTG7 Map Download Manager
  •  Tools Download
  • Thread starterxzenurl
Yes, it works without code if you know the trick. You need to create a second CD or USB with the current map and then it will not ask for a code.
Please send me information step by step.
Does it work in W212 COMAND APS 2013? Stupid question, but I can't download the file to check.
Reactions:Azar641002
If I'm not mistaken, the username is DLM and the password is DLM. I used to download a map for my 2018 GLA using Garmin Map Audio 20. To use it, you need to download it to your SD card.
For those who want to know the process...
  1. Insert a USB/card with the same update as the current version installed in your car.
  2. When asked if you want to install, swap the drive and confirm.
Now the question is to find the original version... good luck!
Reactions:deepsrd
I have a problem with NTG5, after updating the folder the system starts constantly rebooting every 20 seconds.
Have you ever resolved this issue? I'm hesitant to update without knowing the solution to this problem...
Since I don't see the original maps posted here, I hope this can be done. Here are the minimum maps, most versions. Default pass...
  • mini_maps_ntg45.rar
Reactions:RUDEY, idan586, Gregor and 13 others
Hello! Will this work for updating maps for Garmin Map Pilot on Audio 20 with code 522?
Reactions:stephi94, Azar641002 and friedensstifter
When I expanded the file, I saw that all the files had "EU". Are these all maps of Europe? Any chance you have US versions? According to my system, I have V.11 N. America installed.
Reactions:cbraeburn
Hello, I bought the v19.0 map on AliExpress for 13 euros. Works very well, this is a 2022-3 map, I tried to make a clone but it was impossible.
Reactions:karone
Dexter2478
  • Dexter2478
  • Engineering software and utilities
Dexter2478
Dexter2478
