Need Help Please W166 9G with Faults P073E00, P073000
  • Thread starterlocalmode
localmode
localmode
Warnings
2 / 2
I need help with W166 9G with errors P073E00, P073000.
I changed the electrical plate and made a clone of FC200, but I got errors P073E00, P073000.
All programming is OK.
I changed another plate, but still the same.
Reactions:thebigbadwolf
The fault probably also indicates a faulty pressure sensor. The main symptom of a faulty pressure sensor is the car going into neutral when shifting from neutral to Drive. After four such attempts, the vehicle is damaged. Diagnostic trouble codes for the sensor include P07B700, which indicates an incorrect pressure sensor signal, and P073E00, which indicates that reverse gear will not engage. The causes of these malfunctions may be damage to the membrane inside the pressure sensor or failure of the sensor when the temperature reaches 70–80 degrees.
Reactions:biturbo
  • IlanISR
IlanISR
localmode
  • localmode
jls_rap
  • fafaza
dicsun
