Problem with W204 RPM Fluctuations
  • Thread starterB0bby92
Junior member
Warnings
3 / 1
As you can see in the video, I have a strange problem with a sudden RPM spike on my W204 with the OM646.811 engine and 722.640 (5G) transmission. The car does this under light acceleration under load (small hill) and only between 1200-1500 RPM. At higher RPMs there is no problem.
I really need help because this is driving me crazy.
What I have already done:
The torque converter has been recycled.
The lock solenoid is new.
New oil and filters for engine and transmission.
MAP and MAF sensors are new.
The quantity control valve is new.
The rail pressure sensor and high rail pressure regulator are new.
EGR removed by software and with unplugged connector.
DPF removed physically and software.
The swirl flaps are off.
No diagnostic errors (Xentry 2024).
Please give me some advice.
[ Log in now to view this content ]
Reactions:bghiman and Nessim57
Had the same problem. Updated EGS software.
Reactions:B0bby92
What is EGS my friend? Do you mean transmission control module? What version do you have?
EGS53 WDD2042021F 2010 year.
Reactions:B0bby92
I updated mine to the latest version at the official MB dealer in Bulgaria, but no change.
Check the coding in the gearbox (Rear Axle Ratio) and try to throw in another EGS control unit.
Post the coding line and VIN. I'll check what relation it corresponds to. For example...
1728192087300
Reactions:B0bby92
I extracted this information, can it help?
1728201442962
1728276734542
Check what you have on your rear differential. It should be (2.65).
