SEAFERCHIAVI
I'm stuck and looking for help from someone who has already completed this cluster.
Vehicle: 2002 VW Bora, VDO instrument cluster, Immo 3.
Task: Program a key using the instrument cluster dump (cluster removed, reading via OBD is not possible).
Equipment: Autel IM508, OBDSTAR, Smart Pro.
What I have already done:
My questions:
I would be very grateful for any help. Thank you.
- Read the dump and obtained the PIN code (01436) using an external decoder.
- The PIN code is rejected when attempting to program it on the car.
- Tried the Autel "write key from dump" function - encountered a "BIN file size is not correct" error.
- The chip read is a 24C08.
My questions:
- In which memory chip are the Immo 3 data (PIN + CS) stored on this VDO cluster? Am I reading data from the wrong chip?
- What dump file size for this instrument cluster does Autel expect?
- Do I need both the CS and the PIN for the key programming procedure, or is the PIN alone sufficient to add a key?
- Can you recommend a proven method or tool for obtaining the PIN and CS from a valid dump?
