Smart 451 TPMS
  • Thread starterFebo
Febo
I'm new to Smart, but I hope that someone (and I've seen a lot of very trained people here) can help me.
I have a Smart 451 (2014) and would like to install the TPMS module since I have one.
I think I should use something like Vediamo to enable (code) it.
I found a place and screws to mount the module.
I saw that it should communicate with SAM and I think there should be a cable there, but I can’t find it.
Any ideas?
Hi Febo, I'm not sure I can help since I've never had any experience with TPMS 451, but here's what I'll say.
Where the module is attached you should see the module connector, this connector goes to the SAM.
You will also need/should have a switch that connects to the center console switch bank.
As for coding, take a look at Vediamo and try to match your TMPS with the options shown (I think there are three).
Get a copy of the WIS/ASRA as it contains component locations as well as wiring diagrams for the 451.
Good luck.
You need to code the panel and the TPMS indicator should light up on it. This indicator is only on cars with factory TPMS.
Need a block, wiring to the SAM module (3 wires) and a bus sensor.
Very expensive.
  • Febo
audiomeca
  • Simone
User
  • Febo
modamata
modamata
