W177 Car Wash Coding
  • Thread starternewbymb
newbymb
I have activated the car wash function with DTS Monaco. However, when the mode is turned on, the rain sensor and rear wiper are not disabled, see attached image. The following control units were coded: HU6, DMFL, DMFR, DMRL, DMRR, BCMA2, EZS167 and PARKMAN214. Did I forget some control unit?
How to solve the problem? I need help.
Reactions:BIBSHIGE
Check out Vediamo, you might see more options there.
I haven't worked with Vediamo yet.
The control units are correct.
I suspect there are two parameters not enabled in the HU6.
(056) Vehicle Functions Write:
1. CarWashmode - RainSens - available.
2. CarWashmode - WiperRear - available.
Check that the values are correct.
Maybe the wiper switch is in position 0? Because when it's off, the mode shouldn't turn off the rain sensor and rear wiper :p
Try switching position to 1 or 2.
Sorry. Only now I was able to continue working on the Car Wash Activation project. Both options are available to me. Any other ideas on what to unlock?
It's obvious, but that's not why. Thanks for the advice.
  • Sebb
Sebb
  • iSoda
brend
brend
  • Al73ssan
alip74
alip74
