W213 Activate Auto Highbeam
  • Thread starterKarahan
Karahan
Karahan
I recently bought a W213, I have the front camera that can read tables and also lane assist, but when I try to take the switch back when in auto, it just turns on the highbeam, I cant see the A for light.
How can this be coded, which module should I change and which value?
If you have IHC then switch the light switch to "automatic" and start "high beam" as usual, it will show the "Light on with the A". If you do not switch light to "automatic" the high beam will only work manually as if not present.
I've tried this and the A does not come on.
I've managed to code in ILS to the Comand screen, but still the A in instrument cluster not working.
My car is equipped with the LED High Performance headlights and code for them is 632 when looking up in the VIN decoder.
If anyone have the codings for HL_FL253 and HL_FR253 to make it possible for the automatic high beam please share :)
It is some more than only HLI_FL and HLI_FR.
1. EZS213:
EVC CfgBit_65_96 Write -> 608 -> On
2. MMPC213:
Headlamp style -> LED Static
Headlamp IHC Mode -> 1.0
3. BC_F213:
PLSM_CodIHCOverrideHB -> On
PLSM_CodIHCAutoStart -> On
OLC Allgemein Modell Write PLSM_IHC_Avl -> On
OLC LED-Modul Modell Write PLSM_LAM_IHC -> On
4. HLI_FL253 / HLI_FR253
Service:Fahrzeugdatensatz_IHC_write->DisplayNameBig Grinaten->Value:IHC aktiv stat LED
Reactions:aggelos81 and Karahan
I get error when trying to set this to on, it says, OLC Allgemein Modell Write (NRC = 13)
How to fix this one?
What car? What model year?
Seems to be an old file. Look for a newer one.
My car is W213 2018.
Oh, do I need to get new DTS projects?
I have many DTS Project files. Is it worth using BR213 if usual 213 does not work when trying to code?
What do you mean? Project name or control unit name?
Look the control unit name and then replace the file (CBF or SMR-D). If it's too old, it won't work correctly.
In some cases the file is not suitable for the control unit.
Another cause of problems could be security access issues or incorrect settings in DTS Monaco or setup in general.
Yesterday I ran into an issue where my fresh installation did not recognize my VCI. So I installed everything again and now it works.
My project name is 213 and BR213. I don't know which one to use?
  • serdarsz
serdarsz
  • omer7166
lmdtm
