RatherUnknown
- Solutions
- 1
- 15
Important:
The light switch must be set to automatic mode.
Requirements:
.LED Intelligent Light System (642)
.You must have the blue lights from the factory
.Vediamo / DTS Monaco
ECU 1: HLI FL212 (HSCAN_UDS_500...)
ECU 2: HLI FR212 (HSCAN_UDS_500...)
Perform coding of course for both headlights (left & right).
1. Go to Group: Fahrzeugdatensatz LUC Entwickler
2. PLUC_t_NSI_blau_Dauer_S original value 2.5 change to 10.5
3. PLUC_t_NSI_Delay_S original value 2.6 change to 8.6
4. Click SG codieren
5. Perform hardreset
6. Close car and open with key FOB
Explanation:
NSI blau on channel 3 lights up for 10.5 seconds (with blue light) and turns off the blue channel.
The white light (channel 4) turns on after 8.6 seconds and the headlight starts to shine with normal white light.
Finally, you need to change the intensity of the blue light.
But you need to understand the sequence.
Take a look into the Group Fahrzeugdatensatz LDC Binning Entwickler.
Try it with 100% and 400.00 mA.
If you want to get other colors, you need to change the channels and intensity.
Possible colors, for example: yellow, pink, purple, white, etc.
Requirements:
Explanation:
