XENTRY 06.2023 There is No Actuation Option in ACM
  • Thread starterbmwcoder
bmwcoder
I installed Xentry OpenShell 06.2023 v4 but there is no "Actuations" option in ACM.
Does anyone have a patch?
    Given by R00TR0w
Nothing strange. Professional XENTRY activation solves a lot of problems, not just this one.
If to enable this menu, I am more than sure that nothing in it will work as it should, it will be an illusion.
So there is no reason in patches.
Here is ACM in simulation mode with public activation:
ACM.Public
And exactly the same simulation with the correct system:
ACM.Right
PS. As I wrote once, you need to rewrite core java instructions and many GMF files (not to replace of course) to make XENTRY work in normal way with that "public madness" and if something will be updated in this structure, there will be a total system crash.
Around 2 years ago I enabled...
ACM.Public
ACM.Right
Around 2 years ago I enabled some functions for "greedy sellers" and it was working only for one next XENTRY version as I remember.
Reactions:Bigovic, geo12, evando_castilho and 6 others
Yes that's right, the Actuations menu in Trucks for Xentry depends on the key parameters, you simply use the correct InDia parameters and permissions to take full advantage of your Xentry.
Reactions:evando_castilho and bmwcoder
It will tell you absolutely nothing.
InDia permissions = parameters for generating the XENTRY key.
In other words, these are the internal parameters of the system as a whole, which XENTRY takes from the key.
Reactions:Vivo19, Bigovic, M272 and 2 others
I also have the same problem, the "Actuations" tab does not appear, also does not appear in the ENGINE module, can anyone help me solve this problem?
  • Alexei
Alexei
  • CarTuning
xlouis
X
  • odaishisama
handygraphy
