XENTRY Does Not Detect That the Ignition is On
  • Thread starteromega1
omega1
I have a Chinese clone of C4 MUX DOIP. I installed 12.2023 XENTRY.
The system works great and does its job. One of my friends has a W223 BRABUS car.
There are no problems with the car, we just ran diagnostics on it to check the certificate solution.
Unfortunately, this did not work because XENTRY did not recognize that the car's ignition was on.
As I said, on older cars everything works fine.
Does anyone know what the problem could be, can you help me?
    Given by R00TR0w
There's no point in guessing. Everything is written in "InDia_debug.log".
In my car it doesn't detect it automatically either and shows a warning. At the top of my Xentry there is a check mark telling the Xentry that the ignition is on and working.
Reactions:omega1
You need to activate the program again. This is one of the activation problems.
Reactions:omega1
So should I generate a new key and try? Could this also be a problem?
Yes, I faced the same problem, created a new key and everything was resolved.
I don't know if I understand your problem correctly, but if the problem is that it doesn't detect the car's ignition automatically, have you tried manually selecting the check I sent you in the image?
The ignition problem has been resolved, but now error C003 appears.
The car I tried on is a W223 BRABUS, shipped from America to Europe.
The patch is installed on XENTRY 12.2023, the certificate is valid until 04.2024.
XENTRY shows the following error: AUTHORIZATION FAILED.
POSSIBLE CAUSES
- The server of the diagnostic certificate is not available or does not respond.
Error number: C003
What could be the problem, can anyone help?
Reactions:Real, luki03 and omega1
  • nano5849
Shino
  • odaishisama
odaishisama
Eper
  • Eper
Eper
Eper
