Best Software for Openport 2.0 Clone to Use on W211
  •  Vediamo
  • Thread starternenfret90
nenfret90
I recently ordered a Chinese clone of Tactrix Openport 2.0 with the intention of using it on a 2006 Mercedes-Benz E350 W211 imported from Japan.
I would appreciate it if someone with experience could point out the best software for my car.
I read that XENTRY PassThru v23.09 supports this cloned device, but I am not familiar with the features of each software, such as Vediamo and DTS Monaco.
I am thinking of changing the maximum speed limit (210 km/h) of my car and doing diagnostics.
Reactions:User
  • N
    Given by Nacka
Use Vediamo for your car.
To retrofit the parking sensors on the W211, do they need to be coded? If so, what software should I use?
You need to install the sensors, the parking sensor control module, the front and rear sensor display and all the related wiring. Then you need to code your ZGW to enable the parking sensor. I recommend you use Vediamo for this job. DAS with developer mode can also work, but Vediamo is safer because of the easy backup of the codes.
Reactions:xsesiv and SvOzMaS
If you want to change the maximum allowed speed, you need to unlock the ECU.
  • no2spam
theRogue
theRogue
23K
  • Falconsson
gneff
