Best Software for Openport 2.0 Clone to Use on W211
  •  Vediamo
  • Thread starternenfret90
nenfret90
I recently ordered a Chinese clone of Tactrix Openport 2.0 with the intention of using it on a 2006 Mercedes-Benz E350 W211 imported from Japan.
I would appreciate it if someone with experience could point out the best software for my car.
I read that XENTRY PassThru v23.09 supports this cloned device, but I am not familiar with the features of each software, such as Vediamo and DTS Monaco.
I am thinking of changing the maximum speed limit (210 km/h) of my car and doing diagnostics.
Reactions:User
  • N
    Given by Nacka
Use Vediamo for your car.
Reactions:nenfret90
Who tried Vediamo 5?
If you have the appropriate software installation skills, version 23.9 is all your tasks. But only if the connection is via CAN.
XENTRY PassThru is designed for daily use by technicians to diagnose and perform various maintenance tasks such as maintaining a specific transmission temperature during fluid change operations.
On the other hand, Vediamo and DTS Monaco are designed for engineering purposes and give the operator much deeper access to the vehicle's computers to perform tasks such as reading/writing and reprogramming modules.
For general diagnostic purposes, use XENTRY PassThru as it has protection that will not allow you to accidentally break something. Vediamo and DTS Monaco have no barriers and you are free to do whatever you want, even if it later leads to a catastrophic failure.
If you have a CBF based car, I would recommend using Vediamo instead of DTS Monaco. To remove VMAX, you will use Vediamo. I would recommend looking for a manual and following it very carefully because as I mentioned, there are no restrictions in Vediamo.
Reactions:GTechimports, ExpatMat, raspia and 4 others
As far as I remember the Vediamo files, it is not a problem to make version 5 for Passthru devices.
About 3 or 4 years ago I did this for someone, but I do not remember for whom exactly and these files were lost with my old NAS.
Reactions:X164
Actually you did this a long time ago for my older brother ;)
Reactions:catamaran
Ohh. God. Please find out if this system is still working and write me, you know where.
If you don't know how to use Vediamo, you can easily set up VMAX using DAS in developer mode.
Reactions:xsesiv
To retrofit the parking sensors on the W211, do they need to be coded? If so, what software should I use?
  • pauliusx9
23K
Filip
  • Falconsson
lashe
  • nenfret90
nenfret90
