Best J2534 Interface/Clone
  • Thread starterpauliusx9
pauliusx9
I need a J2534 interface that supports XENTRY PassThru reasonably well, within a £20-£50 budget.
So far my search/recommendations have led me to the Tactrix Openport 2.0 interface (original price £180). However, I'm initially interested in trying out more budget alternatives.
The car is a 2009 W207 E350.
Reactions:mbz01, Bootlok20, sothonnop and 3 others
  • A
    Given by albert
XENTRY PassThru J2534 collections and test reports:
1) DICE (Volvo_VCI)
Battery: OK
Duration of the 5 steps: 1 min 44 sec
Reading the control units: 22 Modules
2) Openport 2.0 (replace R1 with 47k for better performance and to avoid overheating)
Battery: OK
Duration of the 5 steps: 0 min 57 sec
Reading the control units: 41 Modules
3) VAS 5054A
Battery: NOT OK
Duration of the 5 steps: 0 min 55 sec
Reading the control units: 41 Modules (for controller SAK or SAF-XC161CJ-16F40F)
Reading the control units: 32 Modules (for controller SAK-XC167CI-XXXX)
4) Mini VCI for Toyota (generic)
Battery: NOT OK
Duration of the 5 steps: 2 min 10 sec
Reading the control units: 20 Modules
5) Scanmatik
Battery: OK
Duration of the 5...
I bought the Tactrix Openport 2.0 on AliExpress and it's great. I've used it on my Mercedes and my son's Lexus. It's cheap and works great. I paid about $25.
Reactions:clickbait, xsesiv, roteras and 1 other person
VXDIAG with C6 license is also a great choice!
Reactions:Galahead
I am using a fake Tactrix Openport from AliExpress. Didn't work with DAS at first. Works fine after using "Ignition Enabler" and tweaking DAS INI files. Haven't tried coding with Vediamo yet.
I used Openport 2.0, Mini VCI and Scanmatik 2 PRO (all Chinese). All tested on my Smart 451.
Openport is good for diagnostics, coding and flashing. But the USB connector is vulnerable.
Mini VCI is good for diagnostics and coding, but flashing made my TCU unusable (reflashed with Openport).
Mini VCI also has a built-in 120 Ohm CAN bus resistor, which may or may not cause problems.
Scanmatik is good for diagnostics and coding (flashing not tested).
Just my experience, I hope it helps someone.
Reactions:xsesiv and nemiro
Is VXDIAG compatible with genuine XENTRY PassThru? I have original Openport and Scanmatik but they don't allow me to flash the cluster. Is there any alternative other than the original C6?
A friend of mine uses an Openport 2.0 clone that he bought for less than 15 euros and it works great with XENTRY.
Reactions:spacemaster
I have an Openport clone from AliExpress. The voltage regulator burned out after a week.
Fixed with the help of YouTube. Works great. XENTRY, Vediamo, etc.
Reactions:clickbait and SvOzMaS
  • nenfret90
9K
reddeuil
23K
