BMW K+DCAN Cable and Firmware Update
  • Thread starterV3lmu
V3lmu
V3lmu
I use K+DCAN OBD cable. I assume there will be a firmware update available for these cables that will improve the quality of the cable connection etc.
Have you ever done anything like this? How is this even possible?
Reactions:flowjob
  • F
    Given by flowjob
You can update your cable's firmware using this GitHub library, it's compatible with most of the "best" K+DCAN cables. You may want to backup your cable's firmware before installing, just to be sure.
https://github.com/uholeschak/ediabaslib
What's the point of using software with a cable when most systems can connect via Bluetooth? It may be a silly question, but it's easy to understand.
For example, a more stable connection. It is recommended to flash the controller with a cable connection. I do not know if this can be done with the Bluetooth version.
Reactions:Sebdemontpel
Thanks for that explanation. I hadn't thought of that.
I can imagine if the connection drops during the update.
Always flash your controller using a cable. This is the safest option.
Reactions:V3lmu and Sebdemontpel
It might be worth paying a little extra to get an updated cable.
Reactions:V3lmu
I tried this instruction for the above mentioned cable but not sure if it worked.
Just in case, I ordered this cable.
Reactions:Knuffe, ACKID, V3lmu and 1 other person
I already knew that. I already tried to update my cable using these instructions, but I don't know if I succeeded.
  • Matth010500
Matth010500
  • 39fb29dndf
User
6K
