Mercedes w212 nice to know hold function
  • Thread startermrkildal
I just looked in the manual and this option is simply not described there.
Closes all windows. First press the car close button, then press the close button again. To open, press three times, and the windows will open in the same position they were before closing.
I also have a 2013 C207. What year does the air circulation trick apply to?
Typically, if this feature is also available in your car, it will be called "Komfort öffnen/schließen" under "Air conditioning" in your vehicle's owner's manual. You can find it online directly on the Mercedes homepage.
Reactions:idan586
If you hold down the button on the climate control panel and turn off the engine, the fan will continue to run for 30 minutes and use fresh air from the air conditioner.
From the outside, place your finger on the sensor on the door handle, then if you pull the door handle about halfway and hold it there for a few seconds, all the windows and the sunroof will open.
You can also close or open all windows using the key fob. Hold the lock button for a few seconds to close, hold the unlock button to open.
  • MARCOSOFT
aqidi
rimedre
  • rimedre
rimedre
rimedre
mbw211fan
  • mbw211fan
mbw211fan
mbw211fan
