Hi Christiano:
i cleared some codes but still have this issue. see pics
Also with the engine switched on the voltage is 15.xx volts
Are PR26 and PR18 correct values? (rl3_8_8.jpg)
Will i have to physically dismantle the the EPB module from underneath the car and open it up or can it be done remotely
Addtional info
I cleared the yellow codes but only 1 red code still remains
Computer: Parking Brake
DTC 516F68 Emergency release 1.5def
The (p) on the dash keeps flashing then goes off does not appear again and the brake button light behind the gears stick keeps flashing red
PARKING BRAKE
Index
Title
CharacterisationState
DTC50CB14 WARNING LIGHT CIRCUIT CO.0
SAVED
Context when fault appeared
Index
Title
Value
ET011_FF PARKING BRAKE INACTIVE
ET029_FF LAST FPA ACTION BEFORE FAULT REPORTED INACTIVE
ET037_FF ENGINE OPERATING PHASE START
ET001_FF + AFTER IGNITION SUPPLY PRESENT
ET028_FF BRAKE SWITCH INFORMATION ACTIVE
ET042_FF FAULT TYPE Other
PR026_FF NO. OF AUT PARK BRAKE WAKE UP WITH FAULT 30.000000
PR018_FF PRESENCE COUNTER 0.000000
PR019_FF FREQUENCY COUNTER 1.000000
PR012_FF VEHICLE SPEED 0.000000
PR001_FF BATTERY VOLTAGE 12V 9.425000
PR003_FF SLOPE VALUE -2.000000
PR004_FF FORCE MEASUREMENT VALUE 234.000000
Additional data
Index
Value
MILEAGE SINCE LAST APPEARANCE OF FAULT
Index
Title
DTC517577 APPLY
1.DEF
SAVED
Index
Title Value
ET011_FF PARKING BRAKE APPLY
ET029_FF LAST FPA ACTION BEFORE FAULT REPORTED STATUS3
ET037_FF ENGINE OPERATING PHASE OFF
ET001_FF + AFTER IGNITION SUPPLY MISSING
ET028_FF BRAKE SWITCH INFORMATION UNAVAILABLE
ET042_FF FAULT TYPE STATUS1
PR026_FF NO. OF AUT PARK BRAKE WAKE UP WITH FAULT 247.000000
PR019_FF FREQUENCY COUNTER 10.000000
PR012_FF VEHICLE SPEED 326.400000
PR001_FF BATTERY VOLTAGE 12V 11.909000
Index
Value
Index
Title
DTC516F68 EMERGENCY RELEASE
1.DEF
PRESENT
Index
Title
Value
ET037_FF ENGINE OPERATING PHASE INACTIVE
PR026_FF NO. OF AUT PARK BRAKE WAKE UP WITH FAULT 0.000000
PR018_FF PRESENCE COUNTER 15.000000
PR019_FF FREQUENCY COUNTER 15.000000
PR001_FF BATTERY VOLTAGE 12V 7.424000
PR003_FF SLOPE VALUE -128.000000
PR004_FF FORCE MEASUREMENT VALUE 0.000000
Additional data
Index
Value
MILEAGE SINCE LAST APPEARANCE OF FAULT 0
Index
Title
DTC516868 VEHICLE MOVES WITH MAX. PARKING BRAKE -
SAVED
Index
Title
Value
ET028_FF BRAKE SWITCH INFORMATION INACTIVE
PR026_FF NO. OF AUT PARK BRAKE WAKE UP WITH FAULT 255.000000
PR001_FF BATTERY VOLTAGE 12V 12.116000
PR004_FF FORCE MEASUREMENT VALUE 240.000000
Additional data
Index
Value
UCH
Index
Title
Characterisation State
DTC957214 UCH 2 SUPPLY CIRCUIT CO.0
PRESENT
Index Title Value
Additional data
Index
Value
Index
Title
DTC955177 STEERING LOCK 2.DEF
SAVED
Index
Title
Value
ET497_FF CAUSE OF STEERING COLUMN LOCK FAILURE INDETERMINATE
PR091_FF STEERING COLUMN LOCK SUPPLY VOLTAGE 11.900000
PR092_FF VEHICLE SPEED, STEERING COLUMN LOCK 0.000000
Additional data
Index
Value
2. Fault(s) detected
DRIVER'S DOOR
Index
Title
DTCA84112 DRIVER'S DOOR LOCKING CIRCUIT CC.1
Index
Title
PRESENT
DTCA84012 DRIVER'S DOOR LOCKING CIRCUIT CC.1
PRESENT
PARKING BRAKE
Index
Title
Index
Title
SAVED
DTC517577 APPLY 1.DEF SAVED
Index CharacterisationState
Title
DTC516F68 EMERGENCY RELEASE 1.DEF
PRESENT
1/2Index
Title
DTC516868 VEHICLE MOVES WITH MAX. PARKING BRAKE-
SAVED
UCH
Index
Title
Index
Title
PRESENT
SAVED
ESP
Index
Title
DTC407481 EFFECTIVE MEAN TORQUE MULTIPLEXED INFORMATION -
SAVED
