Christiano
- Solutions
- 1
- 14
Hello, here is a guided diagnostic for the DTC516F68:
STEP 1 - PRIORITY IN PROCESSING IN CASE OF ACCUMULATION OF DTC
Prioritize the treatment of the following faults, if they are present or stored:
DTC 50C549
DTC F00316
DTC F00317
DTC F0031C
DTC 517577
Check DTCs for: PARKING BRAKE
Among the DTCs mentioned, are any present or stored?
>YES
Access the corresponding diagnostic methods, using the diagnostic tool interface.
>NO
Take the next step. Step 2 - Visually check the emergency release control
STEP 2 - VISUALLY CHECK THE EMERGENCY RELEASE CONTROL
NOTE
This fault indicates that the assisted parking brake system has been released by the emergency unlocking control (if this is the case, check that the handle protector is not damaged).
The cables are reset when manually releasing the parking brake or automatically (if the fault is present) when driving at more than 2 km/h (the fault becomes memorized).
Check the assembly and condition of the emergency release control. Proceed to repair. (parking brake control)
Is the emergency unlocking control correctly positioned?
>YES
Take the next step. Step 3 - Check the DTC recording context
>NO
Return the emergency release control to conformity. Proceed to repair. (parking brake control)
STEP 3 - CHECK DTC RECORDING CONTEXT
NOTE
This check must be carried out on horizontal ground.
Using the parking brake application control, apply it and note the application value and compare it with the application value recorded by the assisted parking brake computer.
Apply the parking brake. Activate AC002 APPLICATION (PARKING BRAKE)
Read the tightening setpoint value.
PARKING BRAKE PR005 EFFORT SETTING (Value)
Compare the setpoint value with the value recorded by the parking brake computer.
PARKING BRAKE PR004 MEASURED VALUE OF EFFORT (Value)
Do the setpoint and tightening values match?
>YES
This body is compliant. Continue
>NO
Take the next step. Step 4 - Check the condition and conformity of the parking brake cables
STEP 4 - CHECK THE CONDITION AND CONFORMITY OF THE PARKING BRAKE CABLES
Check the assembly and condition of the parking brake cables. Proceed to repair. (primary parking brake cable)
Are the power park brake cables compliant?
>YES
Take the next step. Step 5 - Check the condition and conformity of the rear brake calipers
>NO
Replace the parking brake cables in compliance. Proceed to repair. (primary parking brake cable)
STEP 5 - CHECK THE CONDITION AND CONFORMITY OF THE REAR BRAKE CALIPERS
Check the assembly and condition of the rear brake calipers. Proceed to repair. (front brake caliper assembly)
Are the calipers compliant?
>YES
Take the next step. Step 6 - Check the condition and conformity of the rear brake pads
>NO
Bring the brake calipers back into compliance. Proceed to repair. (front brake caliper assembly)
STEP 6 - CHECK THE CONDITION AND CONFORMITY OF THE REAR BRAKE PADS
Check the assembly and condition of the rear brake pads. Proceed to repair. (front brake pad)
Are the pads compliant?
>YES
Take the next step. Step 7 - Perform a loosening and tightening command
>NO
Bring the pads back into compliance. Proceed to repair. (front brake pad)
STEP 7 - PERFORM A LOOSENING AND TIGHTENING COMMAND
Perform a release and tightening command using the manual control in order to re-engage the brake cables.
Is DTC still present?
>YES
Escalate the problem to the next level of expertise. (SEE, Escalation procedure - generic)
>NO
Continue
After carrying out the checks, also check at the harness socket on the parking brake computer if there is no broken wire because I already had this problem on Laguna III.
DTC 50C549
DTC F00316
DTC F00317
DTC F0031C
DTC 517577
>YES
>NO
NOTE
>YES
>NO
NOTE
>YES
>NO
>YES
>NO
>YES
>NO
>YES
>NO
>YES
>NO
Continue
