User
Member
- 106
Hi,
Does anybody have been similar problems. I have GLK 350 Cdi 4MATIC and problem is that when I accelerate more aggressive then the transmission shift down like it should but then the gear stays on the 4th gear and don't shift up even I release the pedal little bit. The RPM is high and speed comes to over 120 km/h or more still the 4th gear remain in same position. But when I accelerate evenly then the transmission shifting up nicely up to 7th gear. There are not comes any fault code. I have replaced CPV valve and cleaned air mass meters by airmass cleaning spray and before that turbocharger is replaced and transmission oils are changed. Now I drove my car the service to local MB dealer and they tried figure out the reason. They told me that there is cr@cks in inside DPF is cr@cked because there is soot on the outlet on the DPF filter surface and end of the exhaust pipe as well.
Could this "faulted" DPF cause gear up shifting problems on that time when there is a high gas stream volume?
