Special Codings for A/CLA/B/GLB! (PDF)
  • Thread starterrimedre
First of all, have you opened the firewall in the EZS167 module that allows you to continue coding other modules?
Open the firewall on EZS167 as follows:
  1. Go to "Diagnostics Services" -> EZS167 -> "Session", select "Extended Start" and click "Transmit".
  2. Then "Diagnostics Services" -> EZS167 -> Generic Jobs -> "Security Access Level 3B" and click "Transmit".
Reactions:avarec, BIBSHIGE, DnCoding and 2 others
Regarding the Adaptive High Beam Assistant, am I correct in understanding that in the UK we should use left-hand traffic instead of right-hand traffic?
There are three settings:
Code:
EZS167
EVC CfgList_01_0C Write Headlamp Style » 632 HEADLIGHT UNIT LED W. STATIC LIGHT SYSTEM RHT
HU6
056 Vehicle Functions Write ILSTrafficStyle » RightHandTraffic_Auto
SMPC213
003 IHC coding Schreiben » Right hand traffic
Should I use the settings currently set on HU6 for the UK?
I have a W177 180D head unit with the original firmware (pre-FUP). I'd like to know how to update the head unit to the latest FUP4 version myself, as my local dealer refuses to do so without good reason. I would like to update all ECUs to the latest firmware versions.
I suggest you create your own thread. When you do this, post your software and hardware numbers from the HU6, IC177 and HERMES modules, as well as your VIN number. Then I can send you the latest firmware version available to me for your car.
I'm assuming you have XENTRY and DTS Monaco.
Reactions:Siegfried
Left-hand traffic. I hope this helps.
Reactions:GeorgeF
I've already coded it and everything works!
After I coded Distronic Pro (239) on my CLA 200 a few months ago, infotainment software updates sometimes disable the feature. Previously, this feature appeared automatically, but after the latest update it is still disabled. Has anyone else encountered this problem?
To perform all these coding operations, do I need to unlock only the EZS167 and HU6 ECUs, or do I need to unlock all ECUs according to a specific procedure?
I took the car for a drive today and noticed that the Distronic Pro system was working again. It seems that software updates to the infotainment system can temporarily disable it, but it reactivates after a while. I'm not sure if it reactivated due to calibration while driving or because I was fiddling with the Distronic Pro buttons.
Any ideas on how to change the side marker lights to white (for US and EU)?
ByteRiderz
mbastucoding
iceburn11
momosam
  • mercedes901
mercedes901
