Special Codings for W177 A200 MBUX 6.0
  • Thread starterrimedre
I wanted to activate the AMG Race menu in HU6 for testing purposes. Even though I coded, there were no changes.
I also tried to activate WIFI connection in HU6 but no change happened, maybe there was no coding change in HU6.
I will be happy if you help me with coding.
Do you understand the 3Bs of EZS?
When I try to disable the firewall using 3B in EZS167, it switches to EZS167_Muster and the 3B option disappears.
But when I coded IC177, it was coded successfully?
Have you tried this with Monaco 8.16?
For AMG try this:
Main Write -> AMG -> on
AMG Sport Line -> on
CI Screen -> Type 2
036 AMG Race App Write -> AMG Race App Indication -> available
And after coding:
TAB -> Diagnosis -> HU06 -> Synchronize to Non-volatile Memory Start -> Trasmettere
Synchronize to Non-volatile Memory Results -> Trasmettere
Hard Reset -> Trasmettere
Reactions:MaaX, samo, BIBSHIGE and 1 other person
By the way, the problem is solved.
With DTS Monaco 8.16 all codings worked smoothly.
If someone has the same problem as me, they can install DTS Monaco 8.16 and solve the problem.
Coding that I have successfully completed:
1. More driving modes (Sport Plus, Snow Mode)
2. AMG Menus Activation in MBUX Screen
3. Start/Stop with saving last setting
4. Automatic High Beam (HIGH PERFORMANCE LED)
5. Vehicle Speed Limit raise
6. Enable Fuel Cap warning
  • Love
Reactions:waxxx, clickbait, BIBSHIGE and 1 other person
Hi, could you please share the steps of different codings?
I'd be very interested to hear about the optional snow driving mode and whether it makes a difference (C118 CLA here). I'm keeping an eye on this thread.
I think the firewall in EZS167 was not disabled. That's why HU6 did not transmit and save the coding.
Instructions in DTS:
Diagnostics - EZS167 - Gereric Jobs - Security Access Level - Activate all!
Then in variant coding -> HU6 parameter change & Hard Reset - done :)
Reactions:clickbait
rimedre
supra1khp5
jatoi92
  • jatoi92
cmkfarooque
  • lordfrederiks
effect
