Special Codings for W177 A200 MBUX 6.0
  • Thread starterrimedre
rimedre
rimedre
I have a W177 A200 gasoline car. I want to make various coding for my car and I need information and help about it (I also think that this broad information will be useful for others).
I want to list the coding I want to do below:
1. AMG Supersport theme for instrument cluster
(I know it is not available for 1.33L engine but it is possible with a special emulator, where can I get this emulator and how can I install it on the vehicle?)
2. Sporty engine sound from the loudspeaker in Sport mode
3. More driving modes (Sport Plus, Snow Mode )
4. AMG Menus Activation in MBUX Screen
5. MBUX System update (FUP4 Update)
6. Instrument Cluster software update
7. Start-Stop remember last setting
8. Automatic High Beam (HIGH PERFORMANCE LED)
9. Vehicle Speed Limit raise
10. Enable Fuel Cap warning
I know I'm asking a bit much. But I think we can prepare a guide for these codings and everyone can benefit from it.
My car: Mercedes A Class A200 W177 2018 AMG LINE, Distronic Pro.
Reactions:fedosix
AMG Supersport only with emulation interface and also a minimum version of software must be installed for your ECU to work, as for the fup4 update, you can only do it in a Mercedes workshop or wait for it to arrive via ota.
The first thing you need is to install DTS Monaco and the project of your car model.
It works with this device.
In addition, the latest HU software can be found with the SW Firmware program and can be flashed with DTS Monaco software via DoIP connection.
Where can I find the installation instructions for this module?
Dexter2478, you can find the necessary software here:
Reactions:Dexter2478
DTS Monaco 8.16 is easy to use. I'm not sure you can change everything you want, but most of it can be changed even in the Passthru version.
Most of the things you mentioned can be done using DTS Monaco, these codings are simple.
Unfortunately, coding cannot be done offline using Xentry Passthru.
As you said, coding can be done using DTS Monaco. IC177 (instrument cluster) was coded without problems. But unfortunately, after coding HU6 no changes occurred. I didn't understand what the problem was because I didn't have an error and the coding seemed successful. I think the problem is with the Openport adapter I bought on Aliexpress. Should I buy an ENET cable and encode with it?
I opened a special topic on this problem, the problem is described in detail there:
https://autogmt.com/threads/dts-monaco-coding-problem-with-openport-2-0.1255/
Reactions:BIBSHIGE
If you were able to send the coding, the problem is not in the Openport, perhaps you did the coding incorrectly, tell me what codings you need and I will tell you how to do it.
Reactions:BIBSHIGE and Dexter2478
rimedre
supra1khp5
jatoi92
  • jatoi92
pretrofit
  • lordfrederiks
effect
