VCI C6 Clone vs TabScan T6 Xentry
  • Thread starterFotom
Fotom
Junior member
I bought TabScan T6 Xentry. I wanted to check if all the advertised features of the iOS app would work at least on my car. I also wanted to check how fast and stable the MUX would be compared to the VCI C6 clone with Xentry, Vediamo and DTS Monaco.
For the C6 clone and TabScan I used Dell 5300 with I7 8665U, 32 GB RAM, 500 GB NVMe SSD, Xentry 09.2023, Vediamo 05.01.01, DTS Monaco 8.16, Windows 11 Pro.
For the C6 I installed the latest 1.0.0.5 drivers on one laptop, and for TabScan I installed the latest "TabScan PC Management Tool" on the other laptop. This ensures that the drivers are installed correctly and all the necessary files are downloaded automatically. This is a big advantage of the C6 clone, as I had to contact the seller to get the correct drivers. But in the end, everything was fine.
Both the C6 clone and the TabScan T6 will be detected in Vediamo and DTS Monaco as an eCOM device, with Xentry you don't need to configure anything in the VCI Manager or in the system settings, they are both well configured and after installing the drivers and rebooting they are ready to use.
I started with the C6 clone, doing the usual EIS222 and IC222 bench testing. Interestingly, the C6 took a little longer to gather all the necessary information about the car, after which the quick test began. The T6 was a little quicker.
To confirm my impressions, I ran a quick test on my S205 2017. Both were reliable and fast, but the T6 was again faster at running the quick test and clearing error codes.
In Vediamo both were about the same, I think it's because of Vediamo and the old system architecture. But in DTS Monaco the T6 surprised me again because everything happened much faster than with the C6. Switching from one menu item to another or changing VCDs is much faster. Wow... I sent some videos to the guy with the VXDIAG SE and he was amazed at the incredible speed of the T6.
By the way, both devices, C6 and T6, can be used via WiFi. I accidentally did this with T6, and it worked stable and smoothly. I usually use a cable connection because I want to avoid errors due to slow WiFi or other problems when using WiFi. But this device is very stable.
Both devices worked great in Xentry and all other programs. If anyone wants to see the device in action, just message me, I can send you a video and you will see how fast the T6 is. I may also have some C6 videos, but I sold my C6 kit a few days ago.
Thanks for reading! I'll also look at other features of the TabScan T6 and tell you how they work.
Reactions:Alex TOR, PLuto, ukeblad and 2 others
I don't like the M6 at all and you are right it was the worst tool I have ever owned. VXDIAG was almost as bad.
It's been around for a long time. By the way, the project was designed by Europeans, not Chinese. I think it was made in Altium Designer, a PCB program. One of my colleagues replaced the project with something else, and unfortunately we didn't have any connectors.
They were very expensive, so the Chinese bought them. Of course, they have changed them a lot from 2007 to now. But that was the beginning in PCB, PickPlace SMT, dumps, etc. This project arose from practical needs. People really wanted something.
I remember back then I was still working with PCB Carsoft 7.4, soldering ICS with a soldering iron. It was a great time, the beginning.
9K
  • hafsa
Rade1978
Rade1978
  • odaishisama
odaishisama
