XDOS/XPT Switcher?
  • Thread starterkaliel
kaliel
Still a newbie here, so your expertise is needed. I know that Xentry split installation to XDOS and XPT a while ago, but there are some who say it does have all files for both types installed as well. Now, the question is there a way to switch between XPT and XDOS on the same PC?
My further research led me to find the answer, which is that there is one solution out there!
Your thoughts?
    Given by R00TR0w
Technically it is possible, but it does not make common sense. Naturally this is not only editing the registry and configuration files, as some "geniuses" believe. Especially when you consider that AddOns are not always the same for both systems.
If only for the XENTRY Simulation mode, then this is also stupid, I made a separate program for you.
This is similar to activating XENTRY VCI and SDconnect on XPT, technically this is also possible, but for what purposes, if you have these devices, then you simply do not need XPT.
There is one ideal solution: install two systems (Windows) on one PC.
I don't think XPT and XDOS can be installed in the same image.
XDOS installs the SDconnect Toolkit for the C4 or uses VCI, while XPT uses other communications media - Passthru devices (eg Openport 2.0).
Reactions:geo12
Reactions:JOJO80000, deepblueee, kaliel and 1 other person
Bigovic
9K
  • Marketplace
25K
