Facelift W205 2019 - ENET Cable
  •  XENTRY DTS Monaco
  • Thread starterdannyb13
dannyb13
I searched but couldn't find any decent info. Does the W205 support ENET via Xentry or DTS Monaco? I have an Openport clone, will there be problems with DTS Monaco 9.02?
  • F
    Given by Fotom
Depending on the model and year, the ENET cable will only work for the audio system and only for flashing (like all HU 5.* systems). The ENET connection is only useful when working with models like the W206 or W223, they offer diagnostics via IP, which is what the cable is for. All other control units will still be accessible via CAN, and this bus will not be installed with either the ENET cable or the other device shown in the thread.
In W205 you will be able to flash HU5S1 only via ENET (DOIP).
Reactions:dannyb13
W206, W223 work with ENET, I checked it myself.
Reactions:kiranabc and Fotom
For ENET connection you can also use Ethernet-OBD adapter like for BMW, the signal flow is the same. But I really like the green adapter, it offers direct CAN bus connection to CGW, and it can be useful for other experiments.
Reactions:Maxtester
Have you tested the BMW adapter yourself?
Reactions:kiranabc
Yes it works on my BMW F20 using ISTA but I can't get it to work on my MB W205 using Xentry or DTS Monaco as suggested above. It only works on HU5S1 (I haven't tried it yet).
Reactions:dannyb13
  • Atilla
Fotom
  • odaishisama
odaishisama
  • PeteM123
soarece
