W213 Ambient Light Premium Coding 877 -> 891question
  • Thread startersatmonster321
Can anyone help me, I have HU55 and ALC213 coded for multicolor version and scenarios and they work fine except the two front footrests do not emit light, I rebuilt LIN via Xentry but they do not work. I looked at all ALC213 arrays but they do not work.
Please can anyone tell me what are the correct ALC213 values for W205 facelift.
satmonster321, was there anything else required other than adjusting the one section of LIN buses and that above mentioned section for HU55?
My HU55 already supports the premium ambient lighting settings, but it's disabled from the factory. I tried flashing ALC213 w/ the above mentioned firmware version, but nothing seems to work.
Not sure if this is relevant, but I have a C238 (The Coupe version of the W213) w/ Data Code 811 (ambient lighting in the ceiling speaker as well).
Currently, it looks like the ambient lighting is potentially not remembering the settings I give it. If I set it to a solid color, it will work, but if I turn on the "Multi-color" mode, all the lights just go dark.
SW HU should be CY18 and ALC213 020305.
For 811 the coding for ALC213 should be accordingly, it is quite difficult to see LIN together with scenarios.
For testing here is W238 without 811.
Code:
VCD_ALC_Szenarien_und_Effekte_Control_VC=02,00,40,00,16,A2
VCD_ALC_Szenarien_und_Effekte_Parameter_VC=3E,00,00,02,3E,00,00,3E,01,01,00,17,01,00,1C,1E,1E,32,00,0A,1E,00,01,00,1F,3E,00,01,3E,00,7A,00,0F,00,17,00,00,28,00,0A,00,05,3E,00,0F,14,1E,05,01,00,17,00,00,0A,00,05,0A,00,28,05,3E,00,3C,1E,64,64,3E,00,02,00,01,32,14,0A,0A,00,0A,02,0A,02,C8,0A,64,0A,0A,0A,00,01,00,02,14,14,05,3E,14,3E,3E
VCD_ALC_Szenarien_und_Effekte_Arrays=01,C8,00,B6,00,01,00,01,00,02,03,C3,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,01,02,03,04,05,00,00,00,00,00,00,00,00,00,00,00,17,00,7A,00,7D,00,80,00,83,00,86,00,89,00,8C,00,8F,00,93,00,96,00,99,00,9C,00,9F,00,A3,00,A7,00,17,00,00,00,00,00,00,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,00,03,00,03,00,A2,00,A8,00,03,00,35,00,02,00,5A,00,01,00,02,00,03,00,01,00,02,00,03,00,17,01,58,00,7F,00,03,00,3B,00,3B,00,08,00,48,00,62,00,17,00,17,00,17,00,A8,00,48,00,72,00,08,3E,19,25,2F,32,3E,3E,3E,3E,3E,3E,3E,19,25,2F,32,3E,3E,3E,3E,3E,3E,3E,19,25,2B,32,3E,3E,3E,3E,3E,3E,3E,0C,19,25,2B,32,3E,3E,3E,3E,3E,3E,00,0C,19,25,2B,32,3E,3E,3E,3E,00,08,00,1C,00,72,01,26,00,35,00,3B,00,08,00,08,00,08,00,08,00,08,00,35,00,1C,00,72,01,26,00,35,00,3B,00,08,00,08,00,08,00,08,00,08,01,26,00,1C,00,1C,00,72,01,26,00,35,00,08,00,08,00,08,00,08,00,08,03,AD,00,1C,00,1C,00,72,01,26,00,35,00,08,00,08,00,08,00,08,00,08,00,72,00,1C,00,1C,00,1C,00,72,01,26,00,35,00,3B,00,3B,00,3B,00,3B,01,05,0A,0A,0A,0A,0A,04,01,01,01,01,0A,0A,0A,0A,0A,0A,04,01,01,01,01,05,06,0A,0A,0A,0A,0A,01,01,01,01,0A,07,07,0A,0A,0A,04,01,01,01,01,0A,04,06,06,0A,0A,04,01,01,01,00,03,00,03,00,A2,00,A8,00,03,00,35,00,02,00,5A,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,03,07,00,00,00,00,00,3E,3E,3E,3E,3E,01,26,00,3B,02,0D,00,62,03,C3,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,03,00,03,00,03,00,03,00,03,00,03,00,03,00,03,00,03,00,03,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01
VCD_ALC_System_Control=00
VCD_ALC_System_Parameter=1E,00,01,00,00,00,3C,00,03,1F,00,04,02,0C,18,24,30,3E,00,00,00,00,00,01,05,01,05,06,01,03,01,04,04,01,04,04,05,00,04,00,0A,00,02,0A,00,32,00,32,00,50,FF,FF,07,08
VCD_ALO_System_Arrays_01=00,0F,F0,00,3F,00,00,00,1D,FF,00,0F,F0,00,30,00,00,00,1D,FF,00,00,00,00,00,00,00,00,00,00,00,00,00,00,0F,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
VCD_ALO_System_Arrays_02=00,00,00,00,00,00,00,00,00,00,00,0E,A0,00,00,00,00,00,08,80,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,3F,00,00,00,00,00,00,00,00,00,38
VCD_ALO_System_Arrays_03=00,00,00,00,00,00,00,00,00,07,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
VCD_ALO_System_Arrays_04=00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,01,50,00,30,00,00,00,04,40,00,0E,A0,00,0F,00,00,00,19,BF,00,00,00,00,06,00,00,00,00,00
VCD_ALO_System_Arrays_05=00,00,00,00,09,00,00,00,00,3F,00,01,50,00,00,00,00,00,04,40,00,04,00,00,30,00,00,00,08,80,00,0A,A0,00,00,00,00,00,11,00,00,01,50,00,30,00,00,00,04,40
VCD_ALO_System_Arrays_06=00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
VCD_ALO_System_Arrays_10=0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27,28,29,2A,2B,2C,2D,2E,2F,30,31,32,33,34,35,36,37,38,39,3A,3B,3C,3D,3E,3F,40,41,42,43,44,45,46,47,48,49,4A,4B,4C,4D,4E,4F,50
VCD_ALO_System_Arrays_07=00,00,00,00,00,00,00,02,00,74,00,00,00,00,00,00,00,20,0C,01,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,01
VCD_LIN_predefined_network_configuration_1=09,03,00,00,06,00,08,00
VCD_ECU_HW_configuration=17,F0
VCD_ECU_SNPD_Bus_Shunt_Timings=00,00,00,00,00,00
VCD_ECU_SNPD_Bus_Switch_Timings=00,00,00,00,00,00
Reactions:bosskurt
The W205 was never equipped with 891.
There are some tricks to enable 891 on a W205, but it will require rerouting some wires.
Could you please tell me what are these tricks that will help me finally put an end to the ambient lighting that is giving me problems? Thank you very much.
  • satmonster321
waxxx
rimedre
12K
Hzr
Hzr
