DTS Monaco v9.02.001
  •  Activation Download
For a cheap PassThru device like OP 2.0, you need to copy the following to a REG file and double click it to import into the Windows Registry.
You'll see this PassThru device as an option in Monaco 9 later.
Code:
Windows Registry Editor Version 5.00
"Name"="OpenPort 2.0 J2534 ISO/CAN/VPW/PWM"
"Vendor"="Tactrix Inc."
"ConfigApplication"=""
"DeviceId"=dword:00000000
"CAN"=dword:00000001
"ISO9141"=dword:00000001
"ISO9141_CH1"=dword:00000001
"ISO9141_CH2"=dword:00000001
"ISO9141_CH3"=dword:00000001
"ISO14230"=dword:00000001
"ISO14230_CH1"=dword:00000001
"ISO14230_CH2"=dword:00000001
"ISO14230_CH3"=dword:00000001
"ISO15765"=dword:00000001
"J1850PWM"=dword:00000000
"J1850VPW"=dword:00000000
"FunctionLibrary"="C:\\Windows\\SysWOW64\\op20pt32.dll"
Device settings:
D-PDU API -> Softing AG EDIC_D_PDU_API_11_28_25
Module Type -> J2534
Cable -> J1962_CARB
Vendor Module Name -> Taxtrix Inc.
ISO_11898 -> CAN1
ISO_9141_2_UART -> KLINE7
Reactions:goberr, mbvitebsk, adrianek69 and 4 others
I have a problem with connecting VCI to DTS 9. In DTS 8.14, VCI connects OK, but VCI cannot connect to DTS 9.
I am also struggling with this problem.
DTS 9 doesn't see VCI C6 OEM.
Pdu_api_root_x64:
Code:
<MVCI_PDU_API>
<SHORT_NAME>D_PDU_API_Bosch_MTS6532</SHORT_NAME>
<DESCRIPTION>Daimler - MTS6532, D-PDU API by Bosch</DESCRIPTION>
<SUPPLIER_NAME>Bosch</SUPPLIER_NAME>
<LIBRARY_FILE URI="file://C:\Program Files (x86)\Mercedes-Benz\Bosch\VCI Software (Daimler)_x64\Products\MTS6532\Dynamic Link Libraries\BVTX-VCI-PDU.dll" />
<MODULE_DESCRIPTION_FILE URI="file://C:\Program Files (x86)\Mercedes-Benz\Bosch\VCI Software (Daimler)\Products\MTS6532\SupportFiles\MDF_Bosch_MTS6532.xml" />
<CABLE_DESCRIPTION_FILE URI="file://C:\Program Files (x86)\Mercedes-Benz\Bosch\VCI Software (Daimler)\Products\MTS6532\SupportFiles\CDF_Bosch_Daimler.xml" />
</MVCI_PDU_API>
Does anyone have any ideas?
Edit: Solved, probably due to an incorrect file "cpprest141_2_10.dll" in the "System32" folder.
  • DLL.File.rar
Reactions:Dany_b, mbastucoding, Ajkaro and 4 others
Hi guys, I'm new here. I was wondering if anyone has a video tutorial or instruction file to learn how to use Monaco and Vediamo correctly?
Reactions:deggial666 and Alpmedica
I have DTS Monaco 9 and Openport 2.0. When configuring the adapter, the vendor module name field remains blank and I cannot select a name. Could you help me or give me a tip?
I have just submitted a registry entry solution for this (its awaiting approval from the mods/admins).
I have just sent you a PM with a link to download in the meantime.
Reactions:goberr, SW Solution and geo12
The "Vendor Module Name" does not actually need to be specified, it appears after the MUX is initialized in the system and does not affect anything.
Reactions:mbvitebsk and SW Solution
DTS 9 does not connect to SDconnect. It find it in the system settings. Any help?
This version works with SDconnect without any problems by default.
Access to the multiplexer may be blocked by a firewall.
There is no other reasonable explanation.
Thanks for the answer, the problem was in the firewall.
Can anyone post the DTS 9.02 configuration for eCOM please?
Reactions:wolf38
abubakarameer55
  • abubakarameer55
ahmedmph
ahmedmph
  • Marketplace
  • Avechucho
osart123
