XENTRY Error Message 2014 GLA 200
  • Thread starterraspia
raspia
I performed diagnostics on my 2014 GLA 200 using XENTRY PassThru and Openport. After a quick test, all modules turned green. My goal is to see the remaining fuel on the instrument cluster, but when I go to "Instrument cluster - Adaptations" this error appears.
Any help will be appreciated.
  • R
    Given by raspia
I finally did it. First I got the CBF information from Xentry (IC172). Then in Vediamo I did the coding of the remaining fuel, it was very simple.
Thank you very much and keep helping people like you all helped me.
Offline accounts cannot perform adaptation at all.
Reactions:raspia
Does this only apply to the instrument cluster? Because my air conditioner is modified and now has 7 positions instead of the original 5.
It doesn't matter what the A/C settings are.
You may not be able to adapt all control units. Try other control units.
How did you change the A/C settings? Didn't you change them in DTS Monaco or Vediamo?
I suggest you change this not in Xentry.
Reactions:raspia
Well, as far as I remember, in the "Control Units" view, on the left panel "Air Conditioning", on the right panel "KLA", tab "Adaptations", "Setup", "Manual Adjustments", "Client Wish", and went to 002, changed the value from 5 to 7. Everything worked like clockwork.
The error shown in your image can occur in different ways:
1. Appears if the control unit is not original.
2. There was a power failure in the control unit.
3. General control unit malfunction.
4. Control unit from another car.
I encountered this error on my W204 when I retrofitted the HVAC from a W212, and it reoccurred when the ILS control unit failed (I no longer had access to the unit).
At least it looks like your Xentry is working fine, so there were no installation issues.
Reactions:raspia
Thank you, Fotom, for your reply.
Points 1 and 4: I am pretty sure everything in the car is original as it belonged to a good friend of mine and I have been keeping an eye on the car's life.
Points 2 and 3: After a quick test, everything is green, no failures in any module. Or does it not matter?
I don't know why I can access other, more "sensible" modules, but this one, even after losing connection with it, works fine. This screen opens when I click on the "Adaptations" tab.
I will follow the investigation. If that doesn't work I will try Vediamo, but I am not sure which CBF file to load for the 2014 GLA 200.
Some functions in XENTRY PassThru are protected by Openport 2.0 (mostly only read errors, deletion, data in blocks). Adaptation and coding in certain blocks cannot be maintained. We can do this with Vediamo.
Reactions:raspia
Ok, thanks for the answer. I'll choose Vediamo. Since this is so sensitive, what is the correct CBF file to open in Vediamo for the 2014 X156 model? I have IC204, IC172, IC197 and IC222.
Bigovic
rimedre
12K
Hzr
Hzr
